Back Window Leaking
Old Dec 18, 2009 | 10:36 AM
fieseler82's Avatar
fieseler82
Angry Back Window Leaking
I'm having a problem with the back window leading. The dealership replaced the back sliding window and it still leaks. I then they said it was the top brake lite which they also replaced. After a good rain it once again leaks, I then took it back in and they are now saying its the back sliding window. Is anyone having the same problem? If so what did you do to fix the problem
Old Dec 18, 2009 | 12:27 PM
Coal Train's Avatar
Coal Train
Usually the problem is the third brake light.
Old Dec 19, 2009 | 02:45 PM
fieseler82's Avatar
fieseler82
They replaced the third and now they are saying that they put in a faulty back window. So monday they are going to replace the back window again.
Old Dec 23, 2009 | 09:59 PM
terb's Avatar
terb
I broke mine and it leaked after it was replaced. It turned out to be the primer they use to make the glue to set was bad. Replaced it again and no more leaks.
