V10 to diesel
Old Dec 26, 2009 | 11:01 PM
JoeV10's Avatar
JoeV10
Default V10 to diesel
I have been thinking about yanking the V10 out of my truck and dropping a Cummins in its place. What all would this entail. If I do this I plan on getting a wrecked donor truck mainly so I can get the coolers and the harness. Would a 12 or a 24 valve be better for a swap. How hard would it be to go to a manual, it is an auto now ( I have a feeling is is on borrowed time.) Just curious as to what you guys thought. The truck is the 2500 in my signature.
Old Dec 27, 2009 | 12:57 AM
pizzo's Avatar
pizzo
dodgetrucker75 is who you need to talk to he has a 98-12v converted from v10,afe stg.2 intake,"custom" fuel plate & afc,ddp 3 injectors,4gsk. twins 62/68/13 over 75mm s400, rack plug, 60lb. springs, stg. 2 water/meth
That is all his info in his signature that person is your best bet.
Old Dec 27, 2009 | 11:14 PM
dodgetrucker75's Avatar
dodgetrucker75
if you can get a doner... do it!!! very easy... you can do 12v or 24v, the only problem with doing the 12v in your year is, you need a 98-98.5 firewall mounted pcm, engine harness (engine harness also includes trans harness) and a/c condenser, converting to manual is very easy, everything bolts in, the cummins and the v-10 share the same bellhousing too, except for the 6-speed cummins.
