Gauge Install
Old Dec 31, 2009 | 08:05 PM
2005RAM2500's Avatar
2005RAM2500
Default Gauge Install
I just installed some gauges, i put the fuel pressure gauge on the bottom of the fuel filter. Then I put the Trans temp gauge on the hot line to the trans cooler.
I will install a boost gauge when the correct bolt come in. Also have a EGT gauge to install when I get the time to drill it.
What ranges should these gauges should be reading?
Thanks for your help.
Old Dec 31, 2009 | 08:40 PM
pizzo's Avatar
pizzo
Fuel pressure idk I have a Rail Pressure gauge Mine is not hooked up in the same spot as yours
transmission temp is going to be lower then mine I normally run 140+. My trans temp sensor is mounted in the line and takes the temp of the fluid not the outside of he line... I bought a fitting and made it work..
Boost the if you have stock turbo you should see 32 psi floored
24-26 psi normal driving... lower when at 65 mph see below
EGT varies at 65 mph I am at 500-600 degrees F with boost in the single digits.. empty
unless i go up a small hill or a incline then everything goes up its kinda normal
Max EGT is 1350 or less... Cummins says that they have tested our common rails at 1450 degrees... I am not recommending you run your EGT that high.. 1350 or less and 1350 for a few seconds...
Do yo have any programmers or anything on the truck?
Old Dec 31, 2009 | 08:43 PM
pizzo's Avatar
pizzo
we have to have Pictures of the gauges
Old Dec 31, 2009 | 08:47 PM
2005RAM2500
Thanks for the info.
My truck is mostly stock, just a cold air intake and muffler delete. I am installing gauges now so when i install a programmer this spring I have them and a baseline of my truck.
Will post pic when i get all gauges working, need to get the last bolt for boost gauge.
Old Dec 31, 2009 | 09:13 PM
pizzo's Avatar
pizzo
oh you have one of those... I didn't go that route I drilled & tapped my intake horn...
Your EGT's maybe a little lower with the cold air intake not very much.. When you get the boost hooked up Please post your boost numbers I really want to know what they are..... Thanks hope that helps Pizzo
Old Dec 31, 2009 | 09:16 PM
2005RAM2500
I will post my boost numbers when I can. Do you think the boost numbers will be significantly different between the 2?
Old Dec 31, 2009 | 10:11 PM
pizzo's Avatar
pizzo
I am not sure, but that is what the cold air intake is supposed to do... If your boosting properly...
Old Jan 1, 2010 | 10:24 AM
Coal Train's Avatar
Coal Train
You're not going to see a significant difference in boost pressures with the intake vs a stock intake.
What you will notice is slightly quicker spool times and "slightly" lower EGT's.
Remember, boost is a measure of restriction not flow. Higher boost doesn't always mean more flow.
The true measure that indicates performance is lbs/min of air.
50 lbs/min at 26 psi vs. 90 lbs/min at 26 psi is a HUGE difference.
Think of it like this (I have to credit Nickbeek with this one).....
If you're filling a swimming pool, do you want to use a 5/8" garden hose at residential pressure or a 3" firehose?.....
