02 Ram diesel no power at first
Old Jan 8, 2010 | 08:16 PM
Lindakz's Avatar
Lindakz
Smile 02 Ram diesel no power at first
Hi. I have an 02 Dodge Diesel. When I start it it's fine but when I start to go I can only go about 20mph until it's warmed up a bit......maybe a mile or so then it's fine.
I've tried shifting gears and sometimes that works to throw it into low and work my way up. (it's an automatic).
Any suggestions if it's a sensor, tranny, etc would be deeply appreciated.....thanks!
Old Jan 24, 2010 | 10:22 PM
mike5742's Avatar
mike5742
I am having the same problem on my 2001. Can it be the cam sensor?
Thanks
Mike
Old Jan 24, 2010 | 10:53 PM
pizzo's Avatar
pizzo
You guys need to check your fuel pressure.. It should be around 15 - 16psi key on engine off and above 10 psi at idle.. Some will say 7 psi. if it is at 7 psi I would change your fuel filter see what the pressure is at... if it don't change then replace lift pump...
Lift pumps provide Fuel to the Vp 44 injection pump. Once the lift pump goes you have a few miles of driving till the Vp44 pump goes... then you will have a code.
Do you guys have any codes.
Old Jan 24, 2010 | 10:54 PM
pizzo's Avatar
pizzo
Thanks
Mike
Cam sensor will give you a code do you have a cam sensor code?
Old Jan 25, 2010 | 01:08 PM
mike5742's Avatar
mike5742
I have an injector timing fault code. I believe it is P0216. I was told it
might be the injector pump, but more likely the cam sensor. I have a new, re-designed lift pump and a new fuel filter. I an getting 18 psi of fuel pressure. I can shut the truck off and restart it and have full power. Thanks guys!
Mike
Old Jan 25, 2010 | 01:27 PM
Coal Train's Avatar
Coal Train
Not likely a cam sensor.
If the cam sensor goes, the truck will likely not start. If it does it'll sound like and old steam engine.
It'll be blowing white smoke like a steam engine also.
I don't have the codes in front of me right now, I'll check it this evening.
Old Jan 27, 2010 | 05:50 PM
Lindakz's Avatar
Lindakz
Nope, don't have any codes. If I shut the truck off and turn it back on it usually is fine. I had the fuel filter changed about a year or more ago.
Old Jan 27, 2010 | 07:20 PM
dennhop's Avatar
dennhop
Mike
P0216 is vp death code, is definitely NOT your cam....
P0216 Fuel Injection Pump Timing Failure
Time for a new VP...just because you've got a new lift pump now, doesn't mean the old one didn't kill your VP.
Old Jan 27, 2010 | 10:43 PM
pizzo's Avatar
pizzo
CHANGE THE FILTER OMG that has to be clogged up.
