New with fuel leak problem
Old Jan 21, 2010 | 01:58 AM
prmoyers's Avatar
prmoyers
Thanks to all, I now have specific places to look.
Old Jan 21, 2010 | 07:51 AM
Coal Train's Avatar
Coal Train
Originally Posted by dodgetrucker75
on the 95 the filter should screw directly on the head, there is a gasket there and also the water drain on the filter could be leaking too
i believe you are thinking about the first gen filters, thats where they were, but in 94 they moved the heater to the side of the block, just forward of the lift pump, and also put a pre screen in there which the bottom spins off to get to it, and is well known for leaks and pluging up
Ahhh, you're right. Actually I was thinking about the 24V trucks. They have the fuel heater right on top of the filter head.
Here's a diagram of the filter assmebly for your truck. I'll pull the lift pump and pre-screen diagrams this afternoon.
Old Jan 22, 2010 | 11:18 PM
prmoyers's Avatar
prmoyers
Thanks Coal Train, is the wires coming out of the bottom of the screw on filter (16 on diagram) suppose to connect to anything? Mine are just hanging.
Old Jan 23, 2010 | 08:27 AM
Coal Train's Avatar
Coal Train
That should be for the Water In Fuel Sensor.
That wiring comes as part of the drain valve.
Off-hand I can remember if the 94 - 95 models used that sensor, I don't believe they did. The 96 - 98 models did.
Here's the rest of the stuff to look at for leaks. This is the rest of your fuel system in that area.
#1 is the Pre-strainer and heater element
#8 is the transfer pump
#16 is the fuel shut down solenoid.
Old Jan 24, 2010 | 05:17 PM
prmoyers's Avatar
prmoyers
Thanks again Coal Train, I'm gonna start with the filter, I waiting for it to arrive and a half decent day to change it and will move down to to prefilter or transfer pump if necessary. You and the others on this site are greatly appreciated.
Old Feb 16, 2010 | 11:06 PM
Aaronon38s's Avatar
Aaronon38s
This sounds a lot like the leak I had last year, and after doing some looking around, not such an uncommon leak. There is a flexible (rubber type) return hose coming from the overflow valve back to the fuel filter. Most of it is a hard line, but about 12-16inches is soft right between the fuel filter and engine. I had to pull the filter off, then it is held on by a couple hose clamps. Of course, not easy to reach, but a fairly simple fix. I just got a generic diesel line hose for about 35 cents. I just can't remember the size. My brother-in-law drove it like this for almost 2 months before he said anything to me.
