CP3 leak HELP!!!!!!!!!!!
Old Feb 5, 2010 | 01:29 PM
Coal Train's Avatar
Coal Train
The feed line isn't just that fitting. Behind that fitting is a small spring and a check ball that you need to verify is seated correctly.
He went in at an angle with the impact gun on the pump gear nut?!.....
Dude, seriously!....FIRE YOUR MECHANIC!
That nut does NOT need and impact gun on it. It only goes on at 77 ft/lbs.
Also, make sure he didn't try to use the nut and pump gear to PULL the CP3 into place....that's a HUGE no go.
I'm tellin' ya, I think I know what happened to that pump, so don't be surprised if II gives you a call and says they're not covering the damge. I'm just sayin'....be ready for it.
I hope they do, but.....
Look, here is one of my DIY's for removing and installing a CP3. You DO NOT need an impact gun and you DO NOT need to remove the radiator.
Old Feb 5, 2010 | 06:27 PM
hottrodder67's Avatar
hottrodder67
Well don't take this the wrong way coal train but i dont like you right now. . i know excally what he did wrong. FUUUUUCCCCCCKKKK. Thank you very much for this information i shall have a little sit down with him after this weekend. Now i gotta go make a strong cocktail and stare at my truck for a little bit.Thanks again for all the help
Old Feb 5, 2010 | 10:11 PM
Coal Train's Avatar
Coal Train
Believe me, I know how ya feel.
Let me know if there is anything ya need and we'll get ya taken care of.
Old Feb 8, 2010 | 01:28 PM
hottrodder67
Well just got off the phone with Jim from II . They took the pump a part and found the O ring was not put in right. So the rebuilt the whole thing made sure it all works and sending it back to me today . But i did ask how this could have happened they did mention that if you install the pump wrong it could **** up the o ring. So although i dont have to pay for the pump to be fixed. I shall have a talk with my mechanic about how this pump will go back into the truck. i'll try to print out the DYI from your site to show him just so he can understand how to do the F ing job right the first time. Thanks for your time and all your help. i shall be coming to you soon for a meth kit and maybe fire rings if you make them.
Old Feb 8, 2010 | 01:35 PM
hottrodder67
your DYI pics are no longer up. can ya post them one more time. i even checked your website and got nothing.
Old Feb 8, 2010 | 01:51 PM
Coal Train's Avatar
Coal Train
Lemme check, not sure why those pics wouldn't be showing.
They're showing fine for me.
Are you on a work computer? It may have Photobucket blocked.
Old Feb 8, 2010 | 10:29 PM
hottrodder67
ya thanks man i think it might be my business computer that does not allow the pics. I shall print them out along with the instrutions for him. Thanks again for the time and information it helped me out a lot. i will keep you posted and let you know what the out come is when i pu tht enew pupm in.
Old Feb 15, 2010 | 11:35 AM
hottrodder67
Put the new pump in from II it works perfect. i still have a little vibration in the truck witch is still puzzling me. I have aftermarket injectors from II, they only have maybe 75k on them. i hope its not that. What else could cause this from pulling the CP3?
