need help 02 dodge cummins computers
Old Feb 4, 2010 | 04:44 PM
rambeast440's Avatar
rambeast440
Default need help 02 dodge cummins computers
my truck is a 2002 dodge 2500 cummins auto tranny
I am getting code
p0606 ecm/pcm processor
p0237 turbo boost sensor A curcuit low
p0121 throttle position sensor A curcuit low input
p0117 engine coolant temp curcuit low input
p0112 intake air temp sensor 1 curcuit low input
all of these codes showed up at the same time while driving home from work The truck will still start and idle but it has no power and the throttle won't rev the engine up. I took it to dodge to diagnose they said it needed new pcm, throttle position sensor and alternator. I changed the throttle sensor and found them a used pcm with same part number throttle sensor did nothing I checked the voltage that the apps was putting out it seems to be fine from idle to wot they tryed to flash the used pcm but said it did nothing.
Then they said it needs a new Ecm, I replaced it and it is still throwing all the same codes wasting alot of money and don't know which way to go maybe I need a new pcm but I have already spent $2000 and have fixed nothing if anyone has any ideas please let me know I can provide more information if needed I have a used spare pcm but i don't know if they can reprogam it to my vin may have to go new but want to make sure before spending anymore
Thanks Matt
Old Feb 4, 2010 | 05:43 PM
dodgetrucker75's Avatar
dodgetrucker75
is the rpm reading correctly on the tach?
Old Feb 5, 2010 | 11:52 AM
rambeast440
rpm is reading right, coolant temp is going between normal and maxed out and check guages light comes on when that happens its not overheating for sure it was -35 outside when it happened
Old Feb 5, 2010 | 05:30 PM
dodgetrucker75
if the computers have been changed, and it does the excact same thing, i doubt they are the cause, it sounds like a bad ground or bad connection some where, check and clean battery and body grounds, check any plugs you can get too, the big square one on the underhood fuse box comes to mind
Old Feb 5, 2010 | 06:24 PM
rambeast440
I'll give that a try thanks
Old Feb 6, 2010 | 12:42 AM
tski's Avatar
tski
the no power problem i have had. replace the boost sensor if need be. its 180 bucks but it might steer ya in the right direction.
