2004 dodge ram 3500
Old Feb 7, 2010 | 04:34 PM
fearless's Avatar
fearless
Default 2004 dodge ram 3500
ok so I bought this truck last week, with 225000 miles on it for $7000 out the door at a dealership.
single cab 5.9 diesel with a 6 speed tranny. Took it home and changed all fluids in the motor and the diff.
Put the truck to work 4 days later hooked up to a 4 car trailer and was loaded with 4 cars and was cruising down the hwy at 65 and then heard a loud pop.
I thought the rear end blew out but my transmission sounds like rocks in a blender now with your foot off the clutch pedal.
as long as you keep the clutch pushed in, theres no noise.
I still have gears, but besides the loud sound, something is rolling around in there and binding up the gears.
My question is, what transmission is in this truck? Where can I find a new one or complete rebuild kits for the transmission at?
Old Feb 10, 2010 | 08:42 PM
pizzo's Avatar
pizzo
I'm bumping this up to the top of the list for you I can't tell you what trans you have. I have a auto and if I put a trans model I may be wrong
Old Feb 10, 2010 | 11:07 PM
Scott91370's Avatar
Scott91370
I wouldn't worry about a new tranny just yet. I have had a spring on a clutch snap before and cause all kinds of racket.
If you have the truck in gear and rev it up does it move forward?
If so, I'd say clutch/pressure plate.
Old Feb 11, 2010 | 06:48 PM
ppc25's Avatar
ppc25
i agree with scott91370. if the noise dissapears when you press the clutch then it is a problem with thrush bearings-pressure plate.
just replace the whole clutch with a heavier duty one if your doing lots of towing.
By the description of the symptoms you gave i would put money on it that this is your problem as i have seen it before.
good luck
Old Feb 12, 2010 | 07:59 PM
fearless's Avatar
fearless
well it was the worst of the worst. The mechanic got inside and saw that the transmission only had about 1 quart of fluid inside and it got too hot and snapped some gears loose. So he said it would probably be best to buy a rebuilt or used one as opposed to rebuilding mine.
Does anybody know where I can find one for a decent price? or maybe a complete rebuild kit with all new insides and gears?
Old Feb 14, 2010 | 10:47 AM
johno2355's Avatar
johno2355
can you get a little bit of warranty help from the dealer you bought the truck from?
I would think there should be a 90day warranty at least.
they shouldn't have delivered the truck to you with out checking the fluids
you only did the rearend and engine oil change.
Old Feb 14, 2010 | 10:10 PM
fearless's Avatar
fearless
they won't offer any help at all.
And Yes I was stupid not to check the tranny oil. I replaced all other oils and they all looked so good that it didn't even cross my mind.
I am to the point to sale the truck as is for $7200 with a bad transmission and cut my losses.
Old Feb 15, 2010 | 07:37 PM
johno2355's Avatar
johno2355
hey don't get me wrong I am not impling that your stupid I just think the dealer should have checked all fluids and stand behind what the sell a bit more
Old Feb 15, 2010 | 07:42 PM
Dieseljunkie's Avatar
Dieseljunkie
The trans you have is an NV5600, and is a great tranny.. You could probably have a rebuilt one installed for about $3,000 and still have a great truck. If you paid 7k for the truck, and 3k for the trans, you're still only into the truck for 10k, and it'll last you for a while yet to come.
Old Feb 16, 2010 | 07:53 PM
fearless's Avatar
fearless
well I was able to pick up a tranny for $1700 out of a wrecked truck with 81k miles on it. so after the labor and price of tranny its going to cost me $2100
