Removing gov sensor & solenoid
Old Mar 5, 2010 | 09:40 AM
Aaron R.'s Avatar
Aaron R.
Default Removing gov sensor & solenoid
1999 3/4ton 4x4 w/Cummins, auto tranny.
I am replacing the governor sensor and solenoid in the transmission. I have the pan off and identified the parts, but am not certain how they are to be removed. They look like push in sensors, but I pried carefully on them and they didn't want to come out of the aluminum block they are in. This aluminum block has bolts to remove it, and I am wondering if there are some snap rings inside holding the sensors in place.
Do I need to remove this block to access snap rings, or do the parts just pry out? I didn't want to remove it and create new problems like small parts falling out and going everywhere.
Old Mar 6, 2010 | 01:17 AM
hundahunta's Avatar
hundahunta
remove the torx bolts and the block need to come out and there is a snap ring hloding the sensor
Old Mar 6, 2010 | 02:40 PM
steve05ram360's Avatar
steve05ram360
and if its not too late... have a look at this site for trans upgrades... allot of them can be done pretty easily.
http://www.transmissioncenter.net/dodge.htm
