AC problem
Old May 12, 2010 | 09:41 AM
dawgfan's Avatar
dawgfan
Default AC problem
Just realized the other day that my AC only blows cold on the drivers side. The vents on the passenger side are blowing plenty of air, but its not cold. And the AC seems to get colder when I come to a stop. This is an 05 CTD 4x4, any suggestions before I take it in to get checked out? I'd just like to have an idea before I go get jerked around. Thanks
Old May 12, 2010 | 10:52 AM
Coal Train's Avatar
Coal Train
Have you tried changing the settings on the mode and blend controls. (i.e. floor vents, defrosters, warm, cold, etc.)
That, too me, sounds like you have the lovely blend or mode door issue that is common in these trucks.
Sounds like it's possibly both of them.
When you turn the fan speed to high, does it get really loud?
Old May 12, 2010 | 04:45 PM
silvercorvette's Avatar
silvercorvette
It seems kind of silly to have separate controls but the past few cars I had allowed the driver and passenger to each set a different temp. My new truck does not have it and I don't miss it but check to see if you have separate controls for driver or passenger.
Old May 12, 2010 | 09:47 PM
brettj2408's Avatar
brettj2408
if you have seperate controls on your control head for passenger and driver you might have a mode door stuck or broken. does your blower motor get louder in recirc?
if you can check your pressures. at static (engine off) pressures they should be right at the temp of the ambient air.
Old May 13, 2010 | 09:16 AM
dawgfan's Avatar
dawgfan
Yes I have tried switching it back ans forth on all settings. Yes it gets louder, and changes to all different modes as it should ie -defrost, vent, floor, etc... and it blows at different strengths as it should-low, med., high. But only cold air out the drivers side.
Is the blend door vacuum or electrically operated?
Old May 13, 2010 | 09:18 AM
dawgfan's Avatar
dawgfan
Nope, no separate controls, unless I am just not smart enough to see it... which is possible!
Old May 13, 2010 | 09:21 AM
dawgfan's Avatar
dawgfan
No separate controls, and yes blower is louder in recirc mode, and blows colder.... but only on drivers side. Where exactly should I check pressures, you referring to the AC line pressures?
Old May 14, 2010 | 01:44 AM
pizzo's Avatar
pizzo
MODE doors are fun.. Are you going to do this yourself or take it to the dealer?? FYI its a big job EVERYTHING has to come out. Steering column, dashboard Everything.. Antifreeze and Freon 134A has to be removed too.. I did both mode and blend doors on my 2004.5.... IT WAS A PITA...
Old May 14, 2010 | 12:53 PM
dawgfan's Avatar
dawgfan
I hope not, going to contact the dealer I purchased it from. They advertise a 4500 mile warranty, even though they gave me no paperwork with it?
Old May 15, 2010 | 06:57 PM
brettj2408's Avatar
brettj2408
we have had many mode doors fail just due to failure but we have also seen objects such as pens stuck in the mode doors shine a light in and make sure no pens or anything is lodged in there because it surely is a PITA
