tachometer hook up
Old May 27, 2010 | 08:15 PM
jmn1960's Avatar
jmn1960
Question tachometer hook up
got a 93 d350 5.9 12v**got a magnetic pick up on the dampner**wires go into this wire harness**truck came with no tach**can i use an ordenary tach or do i need a special one?? where under the dash can i find the two wires coming off that p/u on the crank?? just going to put it up in the windshield area cuz i dont want to drill the dash**so i was think of a 2 1/2 or 3" face**any body got one or any sugesstions?? thanks mike
Old May 28, 2010 | 12:41 AM
dodgetrucker75's Avatar
dodgetrucker75
check out dakota digital on ebay, they have adapters to run any tach you want, with a pickup sensor installed in the bellhousing (thats what i have) or a pickup that goes on the altinator, other wise i dont think any other tach will work, unless you fand an original cluster with a tach, but still, the wiring may/maynot be there, there are also diesel mini tachs, i know summit racing sells them, and they have a pickup that clamps around the altinator, but to me the clamp is a bit of an eye soar and the tach is too small for my likes
Old May 29, 2010 | 11:17 AM
jmn1960's Avatar
jmn1960
thanks
but where can i find the plug under the dash for the exsisting sender?
Old May 29, 2010 | 01:24 PM
dodgetrucker75
well... if its there, its probably part of the gauge cluster, probably have to get a manual and trace the wires...
Old Jun 1, 2010 | 08:12 PM
jmn1960's Avatar
jmn1960
Ok thanks
