2004 5.9 Engine Codes and CEL
Old May 31, 2010 | 02:41 PM
ksszabo's Avatar
ksszabo
Default 2004 5.9 Engine Codes and CEL
All was well until this morning, when I tried to start it. It started ran 10 seconds and stopped running. Repeated this about 5 times, the CEL is on.
My wife used it Friday towing a load of hay in hot (97) weather for about 100 miles. The codes I see after doing the key tric are :
P0148 Fuel Delivery Error
P0236 MAP Sens Too Hi Too Long
P0193 Fuel Rail Press Sens Hi
P0069 MAP-Barometric Press Correlation
P0573 Brake Switch 1 Hi
It has a Predator Power Puck and is set in the low position. It has 4 inch dual stacks on it so exhaust overheating is most likely not the issue.
Does anyone have any ideas or thoughts on this problem?
