2008 dodge ram vibration-off accerator
Old Oct 27, 2009 | 09:29 PM
vmk69's Avatar
vmk69
Default 2008 dodge ram vibration-off accerator
Has anyone experience a vibration in the 3rd Gen Ram 2500 HD when off the accelerator? I thought it was the tranny until I tried putting it in neutral while slowing down, the vibration appears at slower speeds when slowing down and stays until stopped. Does anyone have any suggestions which bearing/u-joints would be the most likely offender? The truck is perfect at all speeds as long as I am on the gas.
Any advise would be great!!!!
Old Oct 27, 2009 | 11:12 PM
Coal Train's Avatar
Coal Train
What model is the truck.
Is it a QC/LB or a SB/MC.
If it has the 2 piece driveshaft, that would be the first place I look.
Check out the center carrier bearing and the u-joints.
Old Oct 29, 2009 | 09:16 PM
vmk69's Avatar
vmk69
It is a Quad cab, I should have also mentioned that it is 4 wheel drive.
Old Oct 29, 2009 | 09:45 PM
pizzo's Avatar
pizzo
It really could be any of them the center carrier is a very good start. if its a u joint 99.9% of the time the squeak. to bad they don't have grease fittings to grease the u joints. really you will need to get under it and check everything out. put it up on jack stands on all 4 so you can spin the tires maybe you will hear it squeak or the center carrier bearing is bad
Old Nov 1, 2009 | 09:43 PM
vmk69's Avatar
vmk69
Thanks for the tips guys!! I've checked all the bearings and can't find any problems. I guess next weekend I'll have try Pizzo's idea and get all 4 wheels off the ground.
I tried running with the jake brake on, the vibration disappeared until I applied the brakes. Are there any issues with the rotors on the 08's? They look alright, but I haven't gone so far as getting them off and turned yet.
Old Nov 6, 2009 | 07:55 PM
vmk69's Avatar
vmk69
Smile Vibration Update
Thanks to those who replyed!!!/Helped!!!!
I have solved my vibration problem. Believe it or not, I torqued the u-bolts on the rear end to 115 ft pds and my vibration has disappeared. The u bolts were at 100 ft pds(10 too low) I don't know why the torque was low but I know my problem. I know they are 5 pds too high now but it worked. I will drive till spring and see what happens. If the problems comes back, I know I need new u bolts, if not, I will replace them next summer anyways.
Old Nov 7, 2009 | 06:40 PM
pizzo's Avatar
pizzo
glad you found that. It would be bad to break while you where driving. My question is did you lift it or anything that the u bolts would have to be loosed up.
I would check them often. to be on the safe side
Old Nov 10, 2009 | 06:11 PM
vmk69's Avatar
vmk69
Default Update!!
No lift, stock suspension all the way around. I have only owned the truck a month, with only 25000 miles and the price I paid, I was ready for some repairs. This was the last and most troubling issue. Probably why the guy sold it so cheap.
Anyways it's fixed and I know what to watch.
I just want to thank the forumn for being here and the members for their time. You all Rock!!!!!
Old May 24, 2010 | 05:42 PM
flhrbgg's Avatar
flhrbgg
Default vibration
Hey, I drive a 2008 dodge ram 2500 4x4 and have the same vibration when I am off the gas. I do not have u-bolts on my drive shaft or a carrier bearing. Right now I am thinking tires.
Old May 31, 2010 | 07:57 PM
vmk69's Avatar
vmk69
Default U-Bolts
The u-bolts I am talking about are the ones that hold the rear differential to the leaf springs of the rear suspension.
Check those
