Can't find vibration source......
Old Jun 17, 2010 | 11:56 PM
nightwalks's Avatar
nightwalks
Exclamation Can't find vibration source......
My rig vibrates since I bought it in March. Mostly highway speeds above 55 it starts. Not a heavy vibration, more of a light one....can see the rear view mirror shake and feels more like I am riding on big knobby tires.
I removed the rims/tires and rebalanced and rotated them...they are true and balanced well. Driveshafts feel tight and no play in the driveline or u-joints I can feel, rear end feels ok also. Should I remove one driveshaft at a time to isolate things?....any ideas? Driving me nuts.
Old Jun 18, 2010 | 01:37 AM
mrfarrell's Avatar
mrfarrell
try coasting and neutral and see if it goes away that way you can eliminate most of the power train..
Old Jun 21, 2010 | 01:42 PM
brettj2408's Avatar
brettj2408
u joint are pretty common in the 3/4 ton. there has to be no stress on the driveline when checking u joints. you will be safe removing the front driveshaft from the truck to isolate the problem.
Old Jun 28, 2010 | 11:26 PM
fireman83's Avatar
fireman83
Don't know if you have the problem figured out yet. But if your truck has a mid-ship bearing in it you might want to check that also I had that same issue with mine.
Old Jul 3, 2010 | 10:38 AM
nightwalks's Avatar
nightwalks
Thanks guys, still haven't found it...no mid-ship bearings and u-joints feel tight. Vibrates only above 60MPH and doesn't go away unless I drive slower then that speed. Very annoying, still feels like I am driving on big knobby tires. Any other ideas?
Is it possible to find a cap to place in the rear of the transfer case so I can drive without the rear driveshaft for a bit just to isolate it?
Old Jul 3, 2010 | 05:20 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
If you're thinking of pulling the rear drive-shaft, I'd just replace the u-joints and be done with it. These trucks eat ball joints and u-joints like crazy. I had a rear u-joint go around 30k and ball joints before 60k.
Old Jul 3, 2010 | 06:18 PM
beefythedodge's Avatar
beefythedodge
i had vibrations like that happen to me before and it turned out to be that i did not have tapered lug nuts that perfectly centered the wheels. other than that did you try and rotate your tires? maybe you have a slight seperation somewhere?
Old Jul 4, 2010 | 02:45 PM
nightwalks's Avatar
nightwalks
Not replacing u-joints needlessly, they aren't loose...I wish it was that easy...and the tires, rims, lugs and balancing are all ok....
Old Jul 4, 2010 | 03:21 PM
Coal Train's Avatar
Coal Train
Normally u-joint vibes are at lower speeds (5 - 15 MPH) and upon acceleration and deceleration.
If it's over 45 MPH's, more than likely it's the tires.
I know you said you had them balanced, but did they get checked for out of round?
They may balance perfect but be as round as a Rubik's Cube.
Old Jul 5, 2010 | 08:08 AM
beefythedodge
that was my point exactly coal. seperations are hard to identify sometimes but they will for damn sure shake your truck. i would rotate the tires to see if you feel the shaking move from the front to the rear and isolate the problem tire.
