Broken wheel stud (front) 2010
Old Jun 23, 2010 | 11:46 PM
mpwr99's Avatar
mpwr99
Default Broken wheel stud (front) 2010
Anyone know what the easiest way to change out one of the fron wheels studs on a 2010 4x4 2500?? I believe it is the same as an 08 or 09? Do i have to loosen that big nut in the middle of brake rotor or will rotor come out once the caliper is removed?
Thanks
Old Jun 24, 2010 | 09:44 AM
brettj2408's Avatar
brettj2408
you remove the whole caliper assembly, rotor, and you might have to take out your wheel speed sensor. then press out the stud aligned with the backing plate access hole.
and reverse for installation
Old Jun 25, 2010 | 10:01 AM
mpwr99's Avatar
mpwr99
Sweet!! I ordered stud from dealer and supposed to have it today. Thank you for your help!
