04 Ram 2500- Stuck Rear Caliper- need input
Old Jul 7, 2010 | 06:29 PM
HayPapi1's Avatar
HayPapi1
Default 04 Ram 2500- Stuck Rear Caliper- need input
Looking for some advice on this issue. My left rear brake caliper is stuck and creating a burning smell from the pads. Mechanic says there are hot spots on the rotor and I will need to replace: rotor, pads, caliper and hose.
Is this the case? Any help, suggestions, links to previous threads, etc. would be appreciated. Looks like a dual piston caliper so it sounds expensive.
Thanks
Old Jul 7, 2010 | 11:46 PM
steve05ram360's Avatar
steve05ram360
you could do a rebuild on it... cheeper than replacing it most of the time. Napa may have one at a decent price, call them. also make sure there is no gunk in the lines when you do replace it, it could be dirt has jammed up the piston(s).
Old Jul 8, 2010 | 12:29 AM
brettj2408's Avatar
brettj2408
yes, i would also flush the brake fluid while your at it and bleed all the brakes with new fluid.
Old Jul 8, 2010 | 01:05 PM
HayPapi1's Avatar
HayPapi1
Thanks!
In your experience do you agree that the rotor has to be replaced as well?
Old Jul 8, 2010 | 01:21 PM
brettj2408's Avatar
brettj2408
to be safe yes, i would replace both, due to the fact of overheating the rotor and possibly warping it
Old Jul 8, 2010 | 03:09 PM
dodgetrucker75's Avatar
dodgetrucker75
you could possibly get it truned if it is within specs, but if its heat checked i would replace it, replacing it is a better idea either way tho, and with a stuck caliper, i would replace caliper with new as it could be damaged internally, and you need hones to properly rebuild it and the whole process can be a real PITA at times
Old Jul 9, 2010 | 02:39 AM
HayPapi1's Avatar
HayPapi1
Thanks guys! Appreciate the assist.
Old Jul 9, 2010 | 10:21 AM
steve05ram360
Originally Posted by HayPapi1
Thanks!
as mentioned... it depends on how much it can be turned to make it true again. if it were me, I'd upgrade & do both sides with new rotors & pads.
