Noise from ac/heater blower
Old Jul 12, 2010 | 09:10 PM
jedrph's Avatar
jedrph
Default Noise from ac/heater blower
Anyone else have this annoying problem? Usually when truck has been sitting all day, i go to start it and there's a very loud and slow clunk...clunk...clunk noise coming from the dash. I know it's related to the ac/heater fan, since it ceases when i turn it off. It sometimes goes away after 10 minutes or so. Is there a baffle in there somewhere that may be flapping open/closed? I didn't think it was the fan because it's not a fast klunking sound, it does speed up slightly if i turn the fan up. just annoying more than anything. Thanks
Old Jul 13, 2010 | 11:52 AM
brettj2408's Avatar
brettj2408
your recirc door is closest to your blower motor and could be weak causing it to flap.
try changing from recirc to non-recirc and see if the noise changes
Old Jul 13, 2010 | 11:25 PM
Scott91370's Avatar
Scott91370
Pull the blower. It should be held in with 3 or 4 screws under the passengers side of the dash. Takes less than 5 minutes. You can feel around in there to see what it could be. Also, you may be suprised what you find- bugs, leaves- stuff like that.
I replaced mine in my 2001 because it was squeeling like mad.
Old Jul 21, 2010 | 10:50 PM
Pog926's Avatar
Pog926
Similar thing happened to me. It sounded like a fan belt had broken loose clunking around. The stealership had to pull the dash and fix a broken recirc. door that came off.
Old Jul 26, 2010 | 09:11 AM
RamQuadHD's Avatar
RamQuadHD
Mine, when I start the engine, I hear a loud bang under dash. Dealer said the blower door is broken and I need to come up with 6-700 to fix it. I never did. 2 years later, everything still works fine.
