Need Help!!!! Dying in S. Texas. No A/C
Old Aug 21, 2010 | 05:08 PM
cooterscuzn's Avatar
cooterscuzn
Default Need Help!!!! Dying in S. Texas. No A/C
A/C was working fine. Made a stop, 2hrs later, start the truck, no A/C. Fan works, all speeds. Heater works, directionals work, but just blows ambiant air. Had a guy diagnos the problem. 2 1/2 days later, he tells me he tracked the problem to the fuse block. Told me the part was very expensive ($2,000+) & I have to have the dealer reprogram my computor. Does anyone know of this? Is this a common problem? Does the fuse block go by a different name? Can it be straight wired? Can I buy the part cheaper online, or in the junk yard? Just doing my home work. Thank you to anyone that can help.
07, 5.9 cummings turbo, crew cab, 4 by 4
COOTER
Old Aug 21, 2010 | 09:17 PM
brettj2408's Avatar
brettj2408
could be anything, clutch relay, compressor, low pressure cutoff switch, high pressure cutoff switch, etc.
what did your pressures look like static and dynamic?
Old Aug 24, 2010 | 12:41 PM
cooterscuzn
With that answer, I can tell you did not really read my post. The problem has been tracked to the fuse block. Looking for answers about the fuse block.
Old Aug 28, 2010 | 05:45 PM
brettj2408's Avatar
brettj2408
is it a reputable shop and which part of the fuse block is bad?
Old Aug 29, 2010 | 02:46 PM
cooterscuzn
Yes sir, I believe this guy runs a reputable shop. He has dodge deisels at is shop all the time. He told me that it was the fuse for the a/c in the fuse block & you have too buy the whole fuse block. You just cant change the a/c fuse in the block. He also told me that the dealer would have to program the fuse block with the computor in my truck. I dont know how true any of this is. I am extreamly novice too electrical aspects of automotive, but I am willing too learn. I just need a good teacher.
Old Aug 30, 2010 | 05:17 PM
brettj2408's Avatar
brettj2408
well all so called fuses are replaceable unless there are solders/defects in the circuit board under the fuses in the pdc(power distribution center)/fuse block.
which is what your saying he diagnosed.
Old Sep 2, 2010 | 08:34 PM
MGibbert's Avatar
MGibbert
I just had the same problem, my compressor was blown cost $1,650 warranty paid everything minus $100 and sales tax. Nice to have a/c again, 103° in Las Vegas today.
