Need some help ASAP
Old Oct 26, 2010 | 02:57 AM
Evolution X's Avatar
Evolution X
I did and couldnt find anything. I like the fact that they provide a youtube video of how to install and everything. I bought it this morning and when it comes in I can hopefully get some time off work to install it
Old Aug 8, 2011 | 07:35 PM
dodge626's Avatar
dodge626
ok guys fass or airdog? lift pump or air fuel separator setup?
Old Aug 8, 2011 | 09:40 PM
horatio102's Avatar
horatio102
FASS and Airdog have some convoluted history, I think they're both owned by the same family, but there may have been some bad blood here and there. Either one will be fine, there may be some minor differences between the two but they perform similarly. Go for the filter setup, it filters much more out than the stock setup, but there's no water in fuel warning light as with the stock setup, you just have to remember to check it periodically.
Old Aug 9, 2011 | 09:25 AM
tiger63's Avatar
tiger63
Horatio is correct about starved injector pumps due to the crappy stock lift pump, once the injector pump begins to slobber and cavitates ; things go south fast.
The new lift pumps are designed to supply various volumes of fuel to the injector pump depending on how bombed you want get. There is a pump for many choices.
A factory rebuild Bosch injector pump is updated with a improved computer to improve performance.
Old Aug 9, 2011 | 04:40 PM
dodge626's Avatar
dodge626
so i guess it all depends on how much i wanted to spend because one make is more expensive then the other and it wont b a all out set up the truck is my daily driver with some towing so it would just be something to make my truck more reliable as will the other things i want to do to the truck in the future
Old Aug 9, 2011 | 08:51 PM
horatio102's Avatar
horatio102
Airdog (standard) is about $630, FASS titanium is about $650, not a significant difference. The single filter FASS is about eighty to a hundred bucks cheaper. I'm running an airdog.
Old Aug 10, 2011 | 04:31 PM
dodge626's Avatar
dodge626
which set up would be good for a daily driver with some towing involved?
Old Aug 10, 2011 | 11:25 PM
horatio102's Avatar
horatio102
Honestly, if you're not going to start cranking up the power, the FASS single filter would probably be excellent. FASS is nice enough to post a cross reference sheet on their website so you know exactly which Donaldson/NAPA/WIX filters will work so you can buy them locally if you want.
Old Aug 11, 2011 | 04:22 PM
dodge626's Avatar
dodge626
i like the idea of the air fuel separator setup yea im not trying to go all out with my truck but i would really like it to be more efficient and make some power but i would be buy like the fass that pumps 95 gph i dont think i need anything higher then that
