Question about a lifted cummins
Old Dec 28, 2010 | 07:43 PM
Jpresdiesel's Avatar
Jpresdiesel
Default Question about a lifted cummins
If a dodge 2500 cummins has an Edge 5 stage chip, 150 hp injectors,HX35/40mm turbo, intake, exhaust, and fass fuel delivery system, will a 6 inch lift and bigger tire make it slow?? Thanks.
Old Dec 28, 2010 | 07:49 PM
dodgetrucker75's Avatar
dodgetrucker75
no, the cummins wont care about the tires, but puts a lot more strees on the trans...
Old Dec 28, 2010 | 07:51 PM
Jpresdiesel
The tranny has a shift kit if that helps? i just question because i have driven atleast 2 dodges (gasoline) that were lifted with big tires and they were slow as hell.
Old Dec 28, 2010 | 07:59 PM
Jpresdiesel
Alright thanks
dodgetrucker75
you wont notice anything with the cummins, unless you go insanely big, you may want to look into a converter, and definatly a trans temp gauge, the biggest killer is stop and go situations
Old Dec 28, 2010 | 10:54 PM
Geezir's Avatar
Geezir
Gas Dodge's can't hold a candle to the Cummins.
Old Dec 29, 2010 | 08:39 PM
horatio102's Avatar
horatio102
Gas trucks have a lot less torque, and the bigger tires change the overall gear ratio. Diesel's make more power down low and more power in general so it's not as noticeable.
