Fuel filter delete!
Old Jan 12, 2011 | 09:42 PM
ecwrestoration@yahoo.com's Avatar
Default Fuel filter delete!
Just installed a dual remote fuel filter systems under the drivers side cab on my 05 ctd and removed the OEM filter housing, would anyone know what do i do with the two elec. plugs that were in the oem cannister (heater & water sensor). If i just let them hang, will i throw codes!
Old Jan 15, 2011 | 03:49 PM
horatio102's Avatar
horatio102
I'd have left the stock filter in place, just plug the holes and leave the sensors plugged into it.
Old Jan 21, 2011 | 10:34 PM
nibroc's Avatar
nibroc
agreed--would have been better to leave the stock filter on --more filtering
Old Jan 23, 2011 | 08:40 PM
horatio102's Avatar
horatio102
I left mine in place, but bypassed it. It may still be full of old fuel even.
Old Jan 25, 2011 | 08:35 PM
spoolandsmoke03's Avatar
spoolandsmoke03
I did the air dog 150 on my 03. Did the fuel filter eliminator as well and it does clean the engine compartment up quite a bit. The sensors are just unplug and don't throw any codes at all. I did hose the engine off last summer and the water in fuel light came on due to the sensor getting wet but it went out the next time I started it. I recommend it, good luck!
Old Jan 26, 2011 | 12:12 AM
Scott91370's Avatar
Scott91370
My water in fuel light will come on if the plug gets wet. Putting them in a baggie would solve this issue.
Old Jan 26, 2011 | 07:31 AM
Tazman40's Avatar
Tazman40
If u are worrying about the plugs and not gonna use them again,i would just take a tube of silicon and goop them full .If u ever had to use them again it wouldnt be to hard to pull the silicon out of the plugs.
