any tips for fuel plate install?
Old Feb 18, 2011 | 02:20 PM
01ramcummins's Avatar
01ramcummins
You have a website? And how does it do on airflow? Id rather have airflow then noise. You know
Old Feb 18, 2011 | 03:57 PM
dodgetrucker75's Avatar
dodgetrucker75
here is my filter, i dont think there is any issue with air flow, 6" inlet i got my original kit from ebay
Old Feb 18, 2011 | 08:59 PM
01ramcummins
Y does yours look sooo much more diff then mine? Wats the blowoff doin up top? And wat is the thing on the other side of the turbo and wats the elbow and line coming off the top of the turbo? Haha. Im so confused
Old Feb 19, 2011 | 11:15 AM
Tazman40's Avatar
Tazman40
Hes running twin turbos,thats why it looks different.
Old Feb 19, 2011 | 12:17 PM
01ramcummins
Ohhhhh. Gotcha. Makea sense. Doesnt look like the twin turbos ive seen. Haha. Looks good man. I like the set up
Old Feb 20, 2011 | 02:03 AM
polish pete's Avatar
polish pete
its because hes running a compound setup instead of a standard twin setup i guess you can call it. and i hope you have a good set of gauges before you mod your pump, otherwise you will melt a piston or two.
Old Feb 20, 2011 | 08:21 AM
01ramcummins
Copy that. I like it. It looks awesome. And yea i need to get some gauges. Wat gauges should i get and in what order? Etc. Most important to least important i know i need them just havnt gotten around to it yet. Lol.
Old Feb 20, 2011 | 10:50 AM
01ramcummins
I was also thinkin of doin a snorkle. Second thinking process. If its possible or a good idea? i like the look and the function. So any ideas or pictures would be awesomely appreciated.
Old Feb 20, 2011 | 03:37 PM
98Dakota's Avatar
98Dakota
I use autometer gauges in a pillar mount ,EGT,Boost and have a fuel gauge mounted down low by the shifter it works great ..If you are gonna start cranking up a 12v these are a must as well as a tranny temp if running a auto tranny..If you get a Feb copy of Diesel Power Magazine it has a good article on adding power to a 12v for free ..
Old Feb 20, 2011 | 04:34 PM
01ramcummins
Adding power for free. As in just basically tweeking the motor and components for power? Sounds good. I saw the one with the 3000hp cummins dodge on front cover. Is it in there? Idk the month of the mag. But yea. Ill check it out. Thanks again. Gauges run like 35 a piece or so right? And do they come with all hardwear to install? Minus the pod
