any tips for fuel plate install?
Old 02-21-2011, 03:39 AM
98Dakota's Avatar
98Dakota
98Dakota is offline
Well it says in big print "King of the Hill" but the article you want to read is called "96hp dodge upgrade-for free they take a old dodge and tweek 96 hp just tweeking what you already have...not sure what the gauges are for cost i just buy what i need but the ones i bought had all you needed to install them pretty much..i don't see anything on the cover about a 3000hp dodge on it it has a pic of a ford and chev on the one i have..
  #22
Old 02-21-2011, 03:43 AM
98Dakota's Avatar
98Dakota
98Dakota is offline
PS: for sure i would not start cranking that motor up without at least a boost and Egt gauges or you might be sorry you could burn it up ...
  #23
Old 02-21-2011, 08:15 AM
01ramcummins's Avatar
01ramcummins
01ramcummins is offline
Cool man. Thanks again. Ill look into getting those gauges. I know i need them just didnt realize how bad. Lol. So ill get that taken care of asap. Easy to install the gsuges? Thanks again
  #24
Old 05-16-2011, 10:30 AM
rl99dram's Avatar
rl99dram
rl99dram is offline
So you prefer to get gauges before fuel plate mod?
  #25
Old 05-16-2011, 01:46 PM
98Dakota's Avatar
98Dakota
98Dakota is offline
Yes i would install gauges first these 12 valve motors once you start turning them up will produce high egt's capable if hurting the motor ...cold air intakes and exhaust help but i would rather know where my egt's are and not burn the motor up..i tune my truck some with egt's when i am pulling my trailer 10000lbs i turn it down some ...and when not crank it up ..
Quick Reply: any tips for fuel plate install?
