diesel exhuast and module package, whats best
Old Jun 24, 2005 | 08:24 AM
SIXPACKSUCKER's Avatar
SIXPACKSUCKER
Default diesel exhuast and module package, whats best
im having a hard time deciding between the whole banks big hoss bundle... $2200!
or the edge juice with attitude module and RBP's 5inch exhuast.... $1400 total with hook up through friend. any input would be greatly appreciated
Old Jun 24, 2005 | 10:23 AM
Drew's Avatar
Drew
Default RE: diesel exhuast and module package, whats best
it all depends on how much you want to dump.
I personaly would be happy with either the Xzillaraider 140hp module, or the VanAiken C3.2 timeing/duration box, also good for 140hp.
however theres one thing you have to look at, the holset HX35 turbo that comes stock on the truck is only good for 450hp. by adding in any high HP system your gunna start stressing the turbo to the point of blowing the compressor wheel or worse.
a good way to go would be to get a good performance box, dump the muffler, and upgrade the turbo. the stock 4 inch exhaust I'm guessing is what you have is more than enough to run upwards of 600+hp.
here is a good list of turbos that work nicely with the Cummins and the max HP they can deliver.
Turbo_______CFM____Racing HP_____Daily HP
HX35_______600________420________330
HX40_______800________560________440
HX50_______1000_______700________550
HX55_______1050_______735________578
HX60_______1600_______1120_______880
H2E________1000_______700________550
HT3B_______1100_______770________605
HT4B_______1800_______1260_______990
HT60_______1400_______980________770
T66________800________560________440
T76________1350_______945________743
T88______1450-1750__1015-1225___798-963
T91________2000_______1400_______1100
T100_______2600_______1820_______1430
T105_______2900_______2030_______1595
Big Brother__1900_______1330_______1045
hope this helps
Old Jun 24, 2005 | 06:58 PM
SIXPACKSUCKER
thanks bud
Old Jun 26, 2005 | 12:12 AM
Avanti's Avatar
Avanti
Issue no. 31 (no date, but it was on the stands a month or two ago) of Trucks, Off Road Accessory Guide had a review identified on the cover, "Confused about diesel programmers? Our guide will get you on the right program."
This may be of some interest to you. If you are interested and cannot find a copy, e-mail me with your mailing address and I'll copy and send.
Ciao!
Old Nov 4, 2005 | 04:46 AM
nexus007's Avatar
nexus007
Drew, from what I have read, the HX35 came stock on the 04.5+ Cummins. I have the '04 Cummins with 305HP motor. Do you know what turbo came stock on that model? Does the list of turbo's you listed also apply to the '04 model or only '04.5 models? Do you know if any of the turbo's on the list are a variable geometry type turbo? Do all of the turbo's on the list mount without any clearance problems? Thanks, much appreciated...Gabe
Old Nov 14, 2005 | 03:40 AM
nlove4ever's Avatar
nlove4ever
Definately go with the Edge With Attitude! My husband is a Diesel Mechanic and they install these all the time. Not only do they repair diesels they do upgrades as well. He did say that Banks has good exhaust, but he wouldnt recommend the chip from Banks. He wanted me to let you know that a 5" is overkill and if you want to save some $ you should go with 4". If it is just a preference of the look/sound, then you can go with the 5".
Old Nov 14, 2005 | 10:16 AM
Drew's Avatar
Drew
the turbo that is on the 305 motor is the HY35 the only difference between the HX and the HY is the compressor houseing is bigger on the HX for more boost.
oh, and all those turbo's listed will fit on engines from the 600 all the way back to the first 5.9L ISB that came out in 89
