2007 Dodge Ram 3500 Vibration
Old May 16, 2011 | 07:55 PM
Leprechaun's Avatar
Leprechaun
Check what speed ur tires are rated for, this may just be me but with the price of fuel I never take my truck above 110km unless I'm passing someone, big trucks aren't ment to go fast, if u wanna go fast buy a sports car..... Lol
Old May 17, 2011 | 12:58 PM
Cbritt9214's Avatar
Cbritt9214
Lol! True, but when time is money I try to pick up the pace. Oh by the way, just had my left side universal joint replaced. From what my mechanic told me they should have a grease fitting but the dodges don't have them. Therfore it wore out after 50k miles. I should expect the right side to start grinding any day now.
Old May 17, 2011 | 02:42 PM
Big Red Goat's Avatar
Big Red Goat
Default 3500 vibration
Funny, but the vibration doesn't start till 105km/hr and doesn't stop till you hit a buck twenty. So speeds above 120 are smooth as silk, must be a hybrid dually sports car...
Old May 18, 2011 | 03:27 AM
98Dakota's Avatar
98Dakota
mine is really smooth up to 190km and really easy to steer to ..LMAO i will let ya know what it does after that after i replace the clutch...
Old May 18, 2011 | 07:10 PM
TannerVest's Avatar
TannerVest
My uncle had the same problem and it ended up being his drive shaft was bent
Old May 20, 2011 | 02:54 AM
rescuewiz's Avatar
rescuewiz
good luck with WARRENTY issues. Hope the 6.7 stays together for you w/all the problems Chrystler is having w/that motor.
Old Aug 10, 2011 | 06:13 PM
Big Red Goat
Just an update to my original post, I finally got rid of the vibration. The dealership balanced my rear tires 'WHILE ON THE TRUCK" I think this was key. I had the tires rebalanced several times by tire shops and had no luck but they did them on a conventional balancer.
Old Apr 11, 2013 | 08:46 PM
garlandellsworth's Avatar
garlandellsworth
Default vibration
I am running a 07 dually ,i asked my mechanic about vibration ,his response if the truck has a two part driveshaft then the steady bearing may be an issue. I am new to the rams so i do not know if they came with the swo part driveshaft. also u joints could cause it.
