Beat New Clutch
Old Mar 17, 2011 | 11:07 AM
98Dakota's Avatar
98Dakota
Default Beat New Clutch
I put a new clutch in last Fall and since i started increasing power with my motor now i am finding the OEM clutches are just not cutting it..so i am wanting to know if the South Bend clutch with be better or any other suggestions as to what i should be putting in?
Old Mar 17, 2011 | 01:17 PM
dodgetrucker75's Avatar
dodgetrucker75
south bend is all i run, make sure you get one rated above the max power level you hope to achieve, other wise you will be changing it again
Old Mar 17, 2011 | 02:51 PM
98Dakota's Avatar
98Dakota
Justin i was thinking about the 475hp one and going with the HD hyd setup as well what do you think?? i have it cranked right now with a #8 plate wide open ,cold air intake setup as well as straight 4inch wide open..the only other thing i might do to this motor is add maybe a new 58mm turbo from BD and some 60hp injectors ...This motor has 400,000km on it and i really don't want to kill it or blow a headgasket if i can help it .as i am set right now i am going to have to turn it down some i think to pull my 5th wheel 28ft without a load pulling a hill i am hitting 800 EGT's with it on the exaust side mounted probe..any suggestion will be well received thanks ...
Old Mar 17, 2011 | 03:22 PM
dodgetrucker75
with that setup, you should well under the 475 mark, i always suggest installing the clutch then seeing if the peddal feel is tolerable for you, if its too stiff, get the hydros, and one piece of advice tho, move that pyro to the manifold, post turbo readings can be way off, i've seen a total engine failure with a reading of 900* post turbo....
Old Mar 17, 2011 | 03:55 PM
98Dakota's Avatar
98Dakota
A couple of years ago i broke my left ankle bad ..metal and all is still in so i will for sure get the new system i don't think my leg can take it without...Guess i will be installing a second pyro do you think drilling with the engine running is fool proof way to make sure no metal gets to the turbo or maybe i should just buy a BD exaust manifold i think they come with it all set up for the thermal coupler? or how do you install yours as far as the drilling and tapping goes?
Old Mar 21, 2011 | 01:31 PM
dodgetrucker75
i try not to say it much lol, but i do drill and tap manifolds with the engine running, just make sure you have good gloves and glasses on cuz there is gona be a lot of very sharp, hot things flyen around
Old Mar 21, 2011 | 11:01 PM
98Dakota's Avatar
98Dakota
Thanks Justin Nuff said ;-) Next days off i will do it and think i am gonna back it off a bit till i get a chance to get the new clutch in as well ...but thanks again for the info
