K&N Vs. What?
Old Apr 12, 2011 | 04:37 PM
Cthulhu's Avatar
Cthulhu
Default K&N Vs. What?
So, I've been watching the posts for a while and it seems to me that the K&N filter on my truck may actually be a liability instead of an asset. The filter intake tube also seems to me to be part of that liability based on the fact I could remove it by hand, without loosening the straps.
What do you guys recommend for a filter/intake replacement? I really do not want to damage the turbo, or frankly ANYTHING downstream on the truck. I've tightened up the strap around the intake tube and it seems much more secure. If the intake holds, do other filters fit the K&N tube or do I need to replace both components?
Looking for recommendations.
Old Apr 12, 2011 | 07:28 PM
InnerCityHillBilly's Avatar
InnerCityHillBilly
i would think you would be able to fit other brands of air filters onto the end of the K&N, i have heard good things about specture
Old Apr 13, 2011 | 06:51 PM
KenZ's Avatar
KenZ
Never used a K&N, but I went with a AEM dry filter. Works great, great quality, and you just wash it and reinstall and your good to go.
Old Apr 17, 2011 | 08:19 PM
horatio102's Avatar
horatio102
My understanding is that S&B is supposed to flow nearly as well but filter much better than the K&N.
Old Apr 17, 2011 | 08:29 PM
HammerZ71's Avatar
HammerZ71
For years there was no matching an oiled filter for a combination of filtering and flow. I've only owned K&Ns over the last 22 years or so and it's currently what I'm running in my CAI, bought in '05. I clean & oil it about every 15k miles which is a little bit sooner than they recommend. You can screw one up if you don't know how to properly clean and re-oil one. A oil-type filter that is dry will flow just as well, but won't filter fine particles at all and could cause damage over a period of time. A good quality oiled filter filters just as well as the better dry filters, IF they are properly oiled.
However, there is a LOT of new technology being used in dry filters that are making them at least as good as the better oiled filters without having the maintenance that you have with oiled filters. Since mine is still in perfect shape, I doubt I'll replace it anytime soon, but if I were looking to buy one today, the dry filters made by AEM, Amsoil, S&B and AFE are all high quality filters that flow at about the same rate as a K&N and are much easier to maintain, without worrying about if you've re-oiled them properly or not...
