2004.5 3500 Transmission service
Old May 29, 2011 | 11:31 AM
98Dakota's Avatar
98Dakota
Default 2004.5 3500 Transmission service
I am doing this for a buddy he wants to take his truck in for a sevice and get the bands adjusted and so on ...he has a edge programmer with three settings other than that the truck is stock and he leaves it on the middle setting..Just wanting to ask if anyone has any suggestions of what he should have done or upgrades to it or issues with these transmissions .. he tows sometimes 17,000 lb load here and there it is a basic cattle farm use truck..The truck has 250,000 km on it now other than regular services has not had any issues..
Old May 29, 2011 | 01:27 PM
Geezir's Avatar
Geezir
what transmission does he have?
Old May 29, 2011 | 11:42 PM
98Dakota's Avatar
98Dakota
i am not sure i am a 12 valve guy all the info i have is what i said ...but i will find out if you let me know how to find out?
Old May 30, 2011 | 11:19 PM
98Dakota's Avatar
98Dakota
Just found out it is a 45 RFE Thanks for any help you can suggest
Old May 31, 2011 | 10:07 PM
horatio102's Avatar
horatio102
45rfe is found in 99/00 grand cherokees and 00 dakotas/durangos with the 4.7 v8. 545rfe is behind every other 3.7, 4.7, 5.7, 6.1, and 6.4. The 68rfe is found behind the 6.7 cummins.
If your buddy has a 2004.5 Cummins, he's got a 48re. Flush the fluid and keep the bands adjusted, that's about all you can do. Keep the temps down, RPMs up when loaded down...
Old Oct 29, 2013 | 09:34 PM
kdyal1's Avatar
kdyal1
what kind of trans is in a 2004.5 3500 2wd dually with 24 valve cummins
Old Oct 30, 2013 | 01:56 AM
horatio102's Avatar
horatio102
48re if it's an automatic.
And correction for my previous statement, the 545rfe has been used behind many of those, but not all of them in every application.
