dodge ram no power
Old May 31, 2011 | 01:43 PM
drozzo's Avatar
drozzo
Exclamation dodge ram no power
starts up runs good in park idles fine put in gear and has no power and running rough and is pushing when brake on like it wants to go no throttle til its sarts moving
Old Jun 1, 2011 | 03:21 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You gotta give us more than that. At least tell us what year you have and what engine you got.
What maintenance has been done to it? When was the last time you did a tune up and changed spark plugs? Cleaned the throttle body? Any water in the gas? How long as it been like this?
You need to be as informative and descriptive as humanly possible.
Old Jun 2, 2011 | 05:33 PM
drozzo's Avatar
drozzo
2004 dodge ram 2500 diesel automatic stock truck start right up idles in park perfect rev up no problem but one i put in gear and hold brake truck is pushing wanting to go like if you had a stick without clutch pressed in and motor is lugging down if i get the truck rolling it will pick up slowly and once im at about 30 truck will drive fine just cant make a complete stop
Old Jun 3, 2011 | 12:05 AM
lxman1's Avatar
lxman1
Site Moderator
Sounds like the lock-up torque converter clutch is partially engaged. Possibly a bad solenoid or other internal issues. Have you scanned for codes?
Old Jun 3, 2011 | 07:29 AM
drozzo's Avatar
drozzo
yes scanned for codes not getting any
Old Jun 3, 2011 | 08:50 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I will move this over to the CTD section so see if any of them might have more input
Old Jun 3, 2011 | 06:08 PM
drozzo's Avatar
drozzo
thank for tring to help me out bye the way your trucks bad ***
