Anyone know of any problems with the 05 2500's
Old Aug 7, 2005 | 04:23 PM
PRPLHAZ999's Avatar
PRPLHAZ999
Default RE: Anyone know of any problems with the 05 2500's
with the exception of the 4X4. Thats a Dodge problem not a diesel problem though.^
Old Aug 8, 2005 | 10:54 AM
Drew's Avatar
Drew
those of yall with the shakes and vibrations at highway speeds, get the dealership to re-ballance the driveshafts. this is common and an easy fix.
if you get alot of heat about they need to try this and try that, take the truck to a drive line specialty shop and get them to take a look, they have equipment that will ballance that thing better than wheel ballancers.
with the 05's the plastic end caps bug me, thank goodness I got an 04.5 and another issue I have is the dual mass flywheel that is used with the G-65 manual tranny. it is designed to reduce shock loading on the gears. . .thats telling me the tranny cant hold up under the full power of the engine. . .and again, thank goodness I got an 04.5 with the NV5600
Old Aug 8, 2005 | 11:02 PM
canmaninusa's Avatar
canmaninusa
New Member
Well it wasn't the drive shaft or u-joints that was causing my vibration issue. It was the Yoke! So after having it in 5 different times they finally resolved the issue. Has anyone had problems with their 05's windows. My driver sides makes a knocking sound on the way down. They replaced the motor, now the passenger side intermittently is doing the same. Other than that I love the truck, it tows like a son- of- a- beeeyach! [:-]
Old Aug 9, 2005 | 12:34 PM
Drew's Avatar
Drew
no problems with my windows, but the passengers side does move rather slow[&:]
Old Aug 11, 2005 | 02:41 AM
cowboy133's Avatar
cowboy133
Don't forget about the door seal problems. there is a fix for it now though. otherwise the best truck I've ever owned. pulls my 30 ft. 5er like its not even there.
Old Aug 12, 2005 | 03:21 PM
RamRough's Avatar
RamRough
yeay my door seals are show the wear too but to be specific its the outer upper seal that really doesnt do much except for wind. other than the slight ripped area, no problem.
As far as the plastic intercoolers, yeah the first half of the 05's got em including mine. well its still going even after 9000lbs of truck barreling up 8% grades with the performance box letting her hit and stay at 40 lbs of boost. its like a vegas crap roll for me. especially when i hear people popping them at stock levels. I guess i got a good one. I'll be replacing it in a few months though for peace of mind. dumb accountants.
Old Aug 31, 2005 | 10:26 PM
boushek's Avatar
boushek
Not sure if a problem or the norm, but my 2005, 2500 with 180 miles just started showing an oil pressure issue. At NOT while above 1000 RPM, oil pressure reads 40+. At idle (750 RPM) Oil pressure drops to 10-15. Owner manual states 10 and above normal pressure at NOT while at idle.
Old Oct 1, 2005 | 02:33 PM
lanham's Avatar
lanham
Was this a constant vibration or an oscillating vigration?
ORIGINAL: canmaninusa
Yes I bought a brand new 2005 Quad Cab 2500 Cummins. Between 65 and 80mph there's a noticable vibration in the rear end somewhere. Took it in and they said the drive shaft angle was off so they shimmed it up...NO CHANGE....its headed back in on Monday. According to the Service receptionist this has been an issue in the past, currently no fix! For 30K plus you can bet I want it fixed!!!! Does anyone else out there have this problem?
Old Oct 1, 2005 | 02:48 PM
vestpuzzle1's Avatar
vestpuzzle1
U need to buy an older Ram, they are just throwing trucks together now a days. R.V.
