Need Help with Trans. Problems
Old Jul 16, 2005 | 04:50 PM
i_need_help's Avatar
i_need_help
Default Need Help with Trans. Problems
after trans shifts out to highest gear, with or without overdrive selected, it jumps in and out of lock up. it does this intermitently. i drive it 45 miles to work and it does it constantly going to work and then may not do it at all on way home. or vis versa. i have heard that is a symtom of a bad torque converter, and that it could be a computer problem. any ideas of things i can check.
this is a 1995 dodge ram 2500 cummins desile.
Old Jul 16, 2005 | 06:13 PM
Se7eN's Avatar
Se7eN
Default RE: Need Help with Trans. Problems
if its a 45RFE it would be a Selonid and presure switch on the valve body, did a job on a dakota last week that had same prob, parts are cheap and its easy to change.
i'll get some info on it for ya so your not totally lost
Se7eN
