What Diff Oil To Use?
Old Sep 30, 2011 | 10:25 PM
bisonboy02's Avatar
bisonboy02
Default What Diff Oil To Use?
I am changing the front and rear diff oils on my 2005 Ram 3500 CTD. I am going to use 75W140 in the rear diff, but should I go with 75W90 or 75W140 in the front?
Any help would be great.
Thanks
Old Oct 1, 2011 | 07:58 PM
horatio102's Avatar
horatio102
I'd go with 90 up front, make sure it's synthetic all around.
Old Nov 21, 2011 | 10:25 PM
AngryWhiteMan's Avatar
AngryWhiteMan
Here is thought for you. You make your own conclusion. 50K miles on Amsoil 75/90 gear lube. Check it at 100K miles. 3:73 rear ratio. I replace the old with new, guess what I use QTip to check the used lube vs the brand new on a very clean white paper towel. I could hardly see the difference. I'm impressed. Use only qualitative lubricants in your truck on everything and you won't be sorry. Lubricants are cheap, repair bill are high.
