03 Automatic Shifting Problem
Old Oct 30, 2011 | 01:15 PM
Bad03Dodge's Avatar
Bad03Dodge
Default 03 Automatic Shifting Problem
2003 with the automatic transmission, 35" Tires
When crusing down the hwy I put the pedal to the floor and the truck downshifts to a lower gear. The problem is that it will just stay in that gear. The truck will stay at redline and never try for another gear. I have to almost completely let off the gas for it to shift up.
With the 35" tires the speedo is about 10 mph off. Is the truck confused by this? Do i need to have the truck calibrated for the tires to get it to shift correctly?
Old Nov 8, 2011 | 12:58 PM
Bad03Dodge's Avatar
Bad03Dodge
Any ideas?????????????????????
Old Nov 8, 2011 | 04:57 PM
Mowhawk's Avatar
Mowhawk
Sounds like your trans is dying. The same thing happened to me and I had to rebuild it, the pressure solenoid went, causing the trans to not want to shift.
Old Nov 8, 2011 | 08:02 PM
Bad03Dodge's Avatar
Bad03Dodge
Not what I wanted to hear
Old Dec 13, 2011 | 02:32 PM
Mowhawk's Avatar
Mowhawk
Sorry bud :/
Old Dec 13, 2011 | 03:11 PM
dalewclark's Avatar
dalewclark
New Member
Default cracked
had the same problem and found out the vlave body had a crack in itchanged it and havent had any more problems in 30,000 miles.
