Does A 3.73 Diff Ratio Need To Be Timed?
Old Nov 1, 2011 | 01:42 AM
bisonboy02's Avatar
bisonboy02
Default Does A 3.73 Diff Ratio Need To Be Timed?
I have a 2005 Dodge 3500 with the 3.73 diff gear ratio and I will be removing the front diff to replace the axle seals. I am needing to know if the pinion and ring gear need to be timed when installed. I can't find any info in the shop manual or online. Any info would be great.
Thanks
Old Nov 1, 2011 | 09:03 AM
Mr. Beefy's Avatar
Mr. Beefy
I've pulled the diffs apart on many trucks I've never heard of "timing" them?
Old Nov 1, 2011 | 07:13 PM
lxman1's Avatar
lxman1
Site Moderator
If you are just replacing the axle seals, you shouldn't have to remove the ring or pinion to do so, so I would say no.
Old Nov 1, 2011 | 08:31 PM
bisonboy02's Avatar
bisonboy02
Anyone else?
Old Nov 2, 2011 | 10:08 AM
Mr. Beefy's Avatar
Mr. Beefy
x2 if your just doing seals you won't have to setup the gear set again... I still have never heard the phrase "timed". Just pull the carrier pound out your seals and put the new ones in.
