1998 dodge cummings 4x4 ...
Old Nov 10, 2011 | 06:47 PM
hummmy's Avatar
hummmy
Default 1998 dodge cummings 4x4 ...
ok i need help .got a diesel trk that starts but only runs few mins and stops will re start .changed just about every thing .grank sens .fuel pump in tank ,alt .had a guy put it on a computor to no avil all we can see is the power to the fuel pump cuts of and then you start it right back up and so on it will not stay running ...any ideas plz help .....wondered if it could be the ign starter box on the colum .this trk has no lift pump i instaled the up graded pump in the tank ...helllllp !!!!!!!!!!!!!!
Old Nov 11, 2011 | 03:49 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! Check out our Cummins Section which is a sub section of our Ram Section!!
Dusty
Old Nov 12, 2011 | 01:13 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will be moving your post to the cummins section. This way you will a answer.
Old Nov 12, 2011 | 05:06 PM
jnicol6600's Avatar
jnicol6600
Swap out the fuel pump relay with another. several of them are the same in the box under the hood. be a good place to start.
