EGR delete
If you install the smarty ME software, then No, it will not regen. On the older smarty SR, if you just ran the "S" software, it would shut off the egr and still regen as required. I don't know if this is the case with the Smarty Jr. On my '08, with the "S" software, you could tell the egr was turned off by the longer warm-up time and the cooler EGT's.
If you try the "S" version you will need to leave everything plugged in, just like stock.
Jeff.
Jeff.
