2011 Laramie 2500 Electrical Problem?
Old Jan 19, 2012 | 02:06 PM
thirtydaZe's Avatar
thirtydaZe
Default 2011 Laramie 2500 Electrical Problem?
Just got my new truck yesterday. First time diesel owner here.
Anyhow, when transferring stuff from old truck to new, i was using the passenger front door. closed the door, away i went only to come back into the garage 5+ minutes later to find that the led lights on my rear view mirror passenger door were still on, and appeared to be the only lights on.
I hopped into the drivers seat, and it also appeared that the evic was lit with 2 horizontal lines.
turned on the key, turned off the key, hopped out, everything shut down properly.
found some more stuff to load into my cab, used the passenger door, same thing happened, this time however the evic was off completely.
it seems that entering the truck from the passenger front illuminates the light, and is potentially stuck on?
any ideas, or just call the salesman?
Old Jan 19, 2012 | 02:54 PM
DodgeCares's Avatar
DodgeCares
Thirty,
There was a TSB for a flash on the exterior courtesy lights on some of the trucks built back at the end of 2010. Not sure if this includes yours but I am posting it just in case. See below.
NUMBER: 08-003-11 REV. B
GROUP: Electrical
DATE: March 17, 2011
SUBJECT:
Flash: Exterior Mirror Courtesy Lamps Stay On Longer Than The Customer Desires.
OVERVIEW:
This bulletin involves checking the software version and, if necessary, flash
reprogramming front Door Control Modules with new software.
GROUP: Electrical
MODELS:
2010-2011 (DS) Ram Truck (1500 Pick Up)
2010-2011 (DD) Ram Truck (3500 Cab Chassis)
2010-2011 (DJ) Ram Truck (2500 Pick Up)
2010-2011 (DX) Ram Truck (Reg Cab Chassis)
2010-2011 (D2) Ram Truck (3500 Pick Up)
2011 (DP) Ram Truck (4500/5500 Cab Chassis)
NOTE: This bulletin applies to vehicles equipped with Exterior Mirror Courtesy
Lights (sales code LEC) built between **January 1, 2010 (MDH 0101XX)** and
December 13, 2010 (1213XX).
SYMPTOM/CONDITION:
The Exterior Mirrors Courtesy Lamps may stay lit longer then the courtesy lighting time out
(after the interior courtesy lights have shut off).
DIAGNOSIS:
If the vehicle operator describes the above Symptom/Condition, perform the Repair
Procedure.
Old Jan 19, 2012 | 03:01 PM
thirtydaZe's Avatar
thirtydaZe
Originally Posted by DodgeCares
Thirty,
GROUP: Electrical
SUBJECT:
OVERVIEW:
GROUP: Electrical
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
Procedure.
Wow! thanks man, i'll be betting that is the problem. thanks for posting!
