fuel
Old Feb 8, 2012 | 07:52 PM
dodge626's Avatar
dodge626
Default fuel
hey guys i was told by someone at the gas station that was looking at my truck which he also had a dodge diesel. i told him that i was getting low mileage right now and he said keep adding additive. well my question is how often should i add it? i was doing it every oil change and then after i talked to him i was thinking every other fill up but im not sure how often i should do it. any help would be nice thanks guys
Old Feb 11, 2012 | 09:43 AM
hillbilli's Avatar
hillbilli
I always run something in every tank, Lucas oil, power service etc... Every bit of lube/cleaner helps. A lot of people on here like "drews brew", havnt tried it myself yet but just do a search for it and youll come up with all kinds of info.
Old Feb 13, 2012 | 01:40 PM
DBLR's Avatar
DBLR
In the wintertime I run a mix of 2 cycle oil and either Power Service or Howe's at every fill up, the mix is 1/4-1/2 oz of 2 cycle oil per gallon of diesel and 1 oz of PS/Howe's to every 3 gallons of diesel.
Old Mar 10, 2012 | 09:51 PM
iwhitne's Avatar
iwhitne
drew's brew doesn't help as much as one would think.. look it up.. there is no scientific evidences that the mmo actually lubricates the inkector pump... I aslo tried power service and 2 cycle.. but my biggest gain came from using schaffer's oil diesel additive.
a $35.00 (1) gallon jug treats up to 2,000 gallons
I put a double treatment in my first tank ran it thru gained about 3 mpg
http://www.schaefferoil.com/diesel-treat-2000-fuel.html
it's good ****!
Old Mar 16, 2012 | 02:50 PM
DBLR's Avatar
DBLR
it's good ****!
FYI that $35.00 Schaeffer additive you bought has many of the same base ingredients that is in Power Service. BTW did you try Power Service without 2 cycle oil or MMO to see how much of an increase in fuel mileage it would get you and at a lower cost?
Old Mar 16, 2012 | 06:29 PM
iwhitne's Avatar
iwhitne
Yeah I tried the power service. worked okay.. schaffer's is cheap.. about $0.01 per gallon to treat. I just finished my second tank with schaffer's and gained 2mpg.
