I have a 95 CTD and need help
Old Mar 9, 2012 | 02:13 PM
Garthogle's Avatar
Garthogle
Default I have a 95 CTD and need help
Hey Men!
Just picked up my truck from a guy who said he took great care of it! lol Well the Coolant tank is dry and has sludge at the bottom. I opened the radiator cap and its green with slight rust. I need to know if I should use anything other than water to flush it? Then what brand of coolant to put back in it?
One other thing...this thing will hit 30-35 PSI of boost and I want to lower that to stock. I looked at the turbo and underneath there looks like a waste gate thing that has a blue hose coming off it but its not hooked up to anything. How do I fix this and put it back to stock?
Thanks..OBTW...I want to flush the brake fluid too...am I right to think DOT 3?
Thanks! Garth
Old Mar 9, 2012 | 07:53 PM
horatio102's Avatar
horatio102
DOT3 is normal, if you're towing heavy I'd flush it with DOT4, which tolerates higher temps.
Drain and recycle the coolant, then I'd just flush with tap water (assuming it's good water, not straight from the river/lake/well), and then fill with a mix of coolant and bulk bottled water. I'd use drinking water instead of distilled, but that's just me.
The hose coming off the wastegate should go to a fitting on the front bottom side of the turbo. The stock fitting is a 90 degree elbow.
Old Mar 9, 2012 | 07:59 PM
Gartho's Avatar
Gartho
ok..I have a plug there...so is it a special type elbow? Or can I just go to lowes and use the brass stuff?
Old Mar 10, 2012 | 10:57 AM
jmn1960's Avatar
jmn1960
1/8npt brass 90* elbow is all it is,, barbed to fit the hose
