Cummins 700HP Engine swap...for the real piston heads on here ;)
Ok so it's not a dodge, but at least it's a cummins
I picked up a brand new Bus Chassis from the Bluebird auction when the factory shut down, and decided to build myself a motorhome for traveling with the family for my son's motocross racing, anyway, the bus had a whimpy POS 410hp Caterpillar in it......... I took it for a drive and decided that Cat C13 had to go. So I bought a brand new Cummins ISX 600HP engine to swap out the Cat.
The Cummins was a DPF/EGR engine........... but I took care of that problem with a custom delete kit
and had the computer reprogramed to 700HP
At first I was excited about having this Caterpillar.
Then I drove it
I started getting ideas
Then all hell breaks loose, and I bought the Cummins
Then I drove it
Of course there was a few modifications that had to be made before we installed the Cummins.......... see ya later EGR and DPF!!!
And a little reprograming here...
Then we could put it in...
Before and after
And not only did I not use a DPF, it's a STRAIGHT PIPE
Before and after
Wow, they are some big a$$ engines...dang!
What's the mpg's you'd expect to get with that beast?
I think the whole DPF crap is BS on Personal vehicles. It should only be required on Company or Fleet vehicles...
