P0603C gen low voltage sence???? What is it??
Old Mar 26, 2012 | 08:10 AM
boxerdiesel's Avatar
boxerdiesel
Default P0603C gen low voltage sence???? What is it??
Have an 07 6.7... Got the check gauges light today and edge is saying its a generator low voltage sence. Truck runs fine, starts fine, volt gauge in normal spot. Truck has original batteries.. Any ideas what it could be, where to start.
Thanks
Old Mar 29, 2012 | 12:25 AM
kissmymagnum's Avatar
kissmymagnum
Think I would start at testing the batteries.. Make sure that they test them separately as some of these kids in the parts places don't seem to get the concept that our trucks have the dual system and the cranking amps reflect on the system as a whole.. Had to tell them that a battery had to be disconnected to test one time and he tried to argue with me.. Both batteries: tested good, separately: tested bad. I am not sure if that is the engine code cause but it cant hurt to be sure, especially with the age. they can check the charging system while they are at it also to be sure that it is really at the voltage that it is telling you on the gauge. You can go local and they will check all of that for free for you
Old Mar 30, 2012 | 07:42 PM
Parts/Service's Avatar
Parts/Service
P063C-GENERATOR VOLTAGE SENSE LOW
Possible Causes
DAMAGED, CORRODED, OR LOOSE CONNECTIONS
(A804) GENERATOR SENSE CIRCUIT SHORTED TO GROUND
(A804) GENERATOR SENSE CIRCUIT OPEN
OPEN CIRCUIT BETWEEN GENERATOR AND AUXILIARY BATTERY
GENERATOR
ECM
Old Apr 9, 2012 | 12:49 AM
AZcummins's Avatar
AZcummins
98 stop truck to pick up son and now truck wont start got fuel to pump but not to injectors
