Brake light and abs light come on
Old Apr 23, 2012 | 06:03 PM
kbrad1956's Avatar
kbrad1956
Default Brake light and abs light come on
I have a 2003 Ram 2500 4wd , with cummins.The brake light and abs light come on when turning the wheels to the right in forward and reverse. When I staighten back up they go off.Hub assembly has been changed on both sides within the year and seem to be ok and brakes seem to be ok.I cleaned the abs sensors.Can anyone help?
Thanks,kbrad
Old Apr 23, 2012 | 08:35 PM
nibroc's Avatar
nibroc
possible short in the wiring
Old Apr 24, 2012 | 06:11 AM
kbrad1956's Avatar
kbrad1956
Default worked with the leads.
I have worked the leads to the sensors thinking it might be that but can't get anything out of it.
Old Apr 25, 2012 | 06:33 PM
00Canuck's Avatar
00Canuck
Had the same thing on my 00. Not sure if it is the same on your year model but it turned out to be the sensor on top of rear transfer case.
Old Apr 27, 2012 | 12:36 AM
horatio102's Avatar
horatio102
Your 00 should have been the speed sensor on the top of the rear differential.
The newer trucks have different axles, and it sounds like there's something wrong in the wiring.
Does the light come on if you're sitting still while turning the wheel back and forth? If so, unbolt one sensor and tie it up somewhere that it won't get moved and try turning the wheel again, then repeat for the other side.
Last edited by horatio102; Apr 28, 2012 at 11:08 AM. Reason: changed year from 01 to 00
Old Apr 27, 2012 | 05:51 AM
kbrad1956's Avatar
kbrad1956
Default lead
It turned out to be the lead wire to the sensor on the wheel hub assembly.I worked with it some more and got it to act up,changed the sensor and wire and that took care of it.
Thanks guys.
Old Apr 29, 2012 | 08:04 AM
nibroc's Avatar
nibroc
glad ya found the culprit
Old Apr 29, 2012 | 11:50 AM
00Canuck's Avatar
00Canuck
your right Horatio102. My bad. It was the speed sensor I was thinking of!! Sorry for any misleading info I sent.
