03 1 ton diesel iIN OUT OF LOCK UP
Old May 22, 2012 | 09:40 AM
Thor Hoefer's Avatar
Thor Hoefer
New Member
Default 03 1 ton diesel iIN OUT OF LOCK UP
It goes in out of lock up! Driving at 35mph 60. How do you fix this? Im desperate. 208-659-1361 Thor
Old May 22, 2012 | 03:11 PM
mantisman51's Avatar
mantisman51
This would be better in the 3rd gen section. Folks there could probably help real quick.
Old May 23, 2012 | 12:52 AM
Thor Hoefer
New Member
Default 03 3500 diesel in out of lock up
When the over drive is on it goes in out of lock up. 45mph 60mph to this Please help 208-659-1361
Old May 24, 2012 | 01:42 AM
horatio102's Avatar
horatio102
Disconnect your batteries and load test them individually. A lot of trans glitches stem from a battery going south.
Old May 24, 2012 | 12:07 PM
Jigabop's Avatar
Jigabop
also check battery cables, make sure they are tight.
if everything checks out there, you may need a new lock up solenoid.
Old May 25, 2012 | 03:44 PM
hillbilli's Avatar
hillbilli
Welcome.
You could be experiancing the enfamous 1-2 shuttle shift common on our 48re transmissions. Common fix is an updated Borg Warner BW51850 pressure sensor and transducer, around $100 on ebay. Check fluid level and condition. Change filter and asjust the bands.
Old May 31, 2012 | 10:18 AM
Thor Hoefer
New Member
new fluid adjusted bands
Old Jun 1, 2012 | 11:26 AM
hillbilli's Avatar
hillbilli
48re is a 3 speed transmission with a 4th overdrive. The TC only lockups in 3rd and 4th dropping ~400rpm's depending on how hard your pushing it. Being only 4 speeds, your going to notice everyshift and lockup due to the gearing. 4th locks between 47 and 51mph, and will unlock around ~44-45. A new pressure transducer may help some.
