P7100 problem
Old Jun 1, 2012 | 12:12 AM
ronnie32567's Avatar
ronnie32567
Default P7100 problem
95 12V will not start, I loosened the inlet fuel line on the P7100 pump, depressed the manual pump several times, plenty of fuel squirting out of inlet line. Then loosened injector line on top of P-pump cranked engine with starter, no fuel coming out of p-pump. The last time I used truck engine cranked right up as it always does. My question is, does the fuel cutoff solenoid/switch go bad often or is the p-pump shot? how do I tell which is bad? Thanks for any info
Old Jun 5, 2012 | 01:24 AM
horatio102's Avatar
horatio102
Unplug the connector to your shutoff solenoid, yank it up, and try starting it. You'll have to manually push the shut off solenoid down again to kill it.
I wouldn't say they go bad often, but they do go bad over time.
