Differential Additive / chatters when making tight turns
Old Jun 21, 2012 | 09:40 AM
Crackshot's Avatar
Crackshot
Default Differential Additive / chatters when making tight turns
Did a fluid change on rear diff and put 4 ounces of LSD additive in there.
Filled the axle and chatters making tight turns. (I obviously need another bottle in there)
My question is, being I filled the pumpkin until it dripped out of the fill hole, if I suck some gear fluid out, should just suck out 4 or so ounces worth and add another 4 ounces?
Reason I ask is because now that the 4 ounces I added is mixed in the gear fluid, is 4 more ounces going to be enough if I suck out some fluid?
What is everyone's thoughts.
Old Jun 21, 2012 | 03:56 PM
skiahh's Avatar
skiahh
I didn't think we needed LSD additive in our diffs?
Old Jun 21, 2012 | 10:41 PM
Crackshot's Avatar
Crackshot
Yeah there is a tag on one of the blots to use it. It is a limited slip diff.
I parked vehicle with passenger side wheels on the curb putting truck on a slight tilt. I added another 4 ounce bottle and seems to be much better now.
