6.9 quit going down road
Old Jul 20, 2012 | 11:54 AM
david t's Avatar
david t
Default 6.9 quit going down road
will run on starting fluid fuel filter is full of fuel no pressur at injecters it sounded like it ran out of fuel would appreaciate some info if you have any
Old Jul 20, 2012 | 01:11 PM
we_the_unforgiven's Avatar
we_the_unforgiven
Going to need some more information. What year is it? How many miles? I'm assuming you're talking about a 5.9L Cummins (1994-2008). The 6.7L Cummins is in the 2008-2013 pickups.
I'm assuming your injection pump is bad.
Old Jul 20, 2012 | 01:15 PM
Jigabop's Avatar
Jigabop
First off, what year of truck are we talking about?
Old Jul 20, 2012 | 01:39 PM
david t's Avatar
david t
Default want start
Im sorry it is 08 6.7
Old Jul 20, 2012 | 01:41 PM
david t's Avatar
david t
It had 170.000 miles
Old Jul 20, 2012 | 05:32 PM
scatpack_69's Avatar
scatpack_69
So, your filter bowl is full of fuel. Are you getting fuel to the CP3 inlet? Crack that line and see if it pushes fuel out.
How do you know it doesn't have pressure to the injectors? I sure as hell hope you aren't cracking the injector lines at the head, pretty dumb with a 30,000 psi-capable system. If you have a rail gauge, what's it showing?
If you have fuel to the CP3, but no pressure in the rail, leads me to believe your CP3 is done.
Old Jul 27, 2012 | 11:36 AM
campermama's Avatar
campermama
Hook up a ODB II, it will tell you what it is.......sounds like fuel pump. Happened to me, was driving along just fine and with no warning at all the truck turned off. I now carry an extra fuel pump with me (mine is not in the tank, thank God!)
