NV4500 to NV5600 swap/ please help!
Old Aug 20, 2012 | 12:39 PM
DDMX138's Avatar
DDMX138
Exclamation NV4500 to NV5600 swap/ please help!
my 1998.5 2500 has been nothing but trouble when it comes to the current transmission. couple nights ago i was towing a 10k trailer up a minor grade and blew third gear out. This tranny has had nothing but bad luck. So i talked to some buddies and they suggested putting a nv5600 in it. I do tow alot so it makes sense but i dont know what other parts i need besides the transmission itself(like driveshafts etc.). Any comments and help is greatly appreciated!
Old Aug 21, 2012 | 01:53 PM
Jigabop's Avatar
Jigabop
I would keep the NV4500. get a rebuilt one with the 5th gear fix, upgrade the input shaft, and overfill it with oil. should hold up to anything you can throw at it...
NV5600 isn't any better. I ripped every single tooth off of 5th gear and snapped the intermediate shaft that 5th and 6th are on in my old one...and I wasnt even towing or loaded with weight..just floored it in 6th from a 55mph rolling start and it broke :-/ got a new one with some fixes in it and running tranny coolers and extra oil now..
Old Aug 21, 2012 | 01:55 PM
Jigabop's Avatar
Jigabop
if you really want to do the swap, you will need the HD xfer case, and drivelines from a truck that had a NV5600 in it. probably need the crossmember for it too.
also note its a very HEAVY trans..weighs ~ 400lbs with no oil in it. it also runs a different oil than the NV4500...you need to run synchromesh transmission oil in it.
Old Aug 23, 2012 | 11:13 AM
DDMX138's Avatar
DDMX138
The new transmission won't bolt up to the transfer case of my nv4500?
Old Aug 23, 2012 | 11:50 AM
Jigabop's Avatar
Jigabop
it might. not positive on that. would definitely make sure you have the HD transfer case..its easy to tell..the HD xfer case has a PTO plate on it just like the transmission.
