12v low idle/stall
Old Aug 28, 2012 | 10:59 PM
DodgeFreq's Avatar
DodgeFreq
Default 12v low idle/stall
dad has a 1994 12v cummins and after its last service its been slowly idling lower and lower till now its at around 350rpm at idle and if i dont keep it at 700rpm manualy it will stall out, if i stop to fast it stalls, if i dont two foot it(one on the gas/one on the brake) and if i goose it real quick it stalls as well? the only thing i can think would cause it is the motor is hurting for fuel but i dont know if its a fuel pump problem or maybe an injection pump problem or where else could cause it if it isnt a fuel problem. any insiht would help and if youve had this problem before what fixed it?
Old Aug 29, 2012 | 11:57 PM
horatio102's Avatar
horatio102
It's possible for the block mount lift pump to head south, get a fuel pressure gauge on it and see where you are. The newer trucks want about 18 psi, the older ones seem to be happier at 30.
Old Sep 4, 2012 | 09:38 AM
hillbilli's Avatar
hillbilli
I would lean toward the LP. Best get that checked before your burn out the Injection pump
Old Oct 13, 2012 | 12:32 PM
DodgeFreq's Avatar
DodgeFreq
changed the lp and still has the low idle condition. took it to the mechanic and he said theres a bolt to tighten on the throttle linkage to get the idle up. dose anyone know where thats at? he wasnt to specific on the location.
Old Oct 15, 2012 | 11:50 PM
horatio102's Avatar
horatio102
Maybe this will help? I didn't watch the whole thing...
http://www.dieselbombers.com/12-valv...lve-p7100.html
Old Oct 16, 2012 | 01:50 PM
DodgeFreq's Avatar
DodgeFreq
thats it thanks
