99 ram 2500 diesel bouncing on highway problem
Old Sep 17, 2012 | 11:13 PM
boilingpoint0's Avatar
boilingpoint0
Default 99 ram 2500 diesel bouncing on highway problem
the truck bounces pretty rough on the highway starts at 50mph. steering wheel does not shimmy when bouncing. changed a bunch of front end parts, alignment, tires balanced even replaced the center bearing for driveshaft and still getting the bouncing sounds like the death wobble but i cant figure it out any suggestions?
*1999 dodge ram 2500 24v cummins, top gun customz short arm 3 inch lift in front helper springs and block in the back think 1.5 inch of lift, brand new 285-75 cooper at/3 tires all around, replaced shocks all around, tierods, track bar*
Old Sep 18, 2012 | 01:10 AM
jasonw's Avatar
jasonw
Site Moderator
What PSI are the tires at? Too high and they can cause problems with that.
Also, for future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Sep 18, 2012 | 04:10 PM
boilingpoint0
I think I'm running from 45-50 psi what is a normal psi I should use and if that's not the problem what else could be wrong or should I try checking?
Old Sep 18, 2012 | 09:27 PM
horatio102's Avatar
horatio102
Tires may be balanced, but are they out of round or flat spotted? You can have a perfect balance even with egg-shaped tires. Get your tires road force balanced and check back. After that, perhaps get your driveshaft balanced.
Old Sep 18, 2012 | 09:46 PM
3dubs's Avatar
3dubs
X2 Mine bounce at 40 but smooth out at 50. Put a little extra air pressure in the tires and see if it stops.
