99 dodge 2500 stalls and fuel injectors keep pumping
Old Nov 21, 2012 | 07:03 AM
jmf614's Avatar
jmf614
Default 99 dodge 2500 stalls and fuel injectors keep pumping
Have a 99 dodge 2500 and it started rite off and then ran rough after 30 seconds. It stalled soon after and the fuel ejectors keep cycling and pumping fuel after it stalls. (wont start due to flooding after this)
Any help or ideas appreciated.
Old Nov 24, 2012 | 07:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I'll move your post to the Diesel section.
Old Nov 25, 2012 | 05:45 PM
Jigabop's Avatar
Jigabop
1 its not going to keep pumping fuel after it stalls... it can't because the pump is gear driven by the motor.
2 a diesel does not flood. it will burn even hotter with more fuel injected into it...
3 sounds like you got air in your injector lines. bleed each line till fuel comes out of each, then try and start it, and once it starts rev it to 2000rpm it should clear out the rest of the air and smooth out the idle.
also check and make sure you don't have any codes.
